Not a solution, instead a suggestion...(was: How to open a HP-41 wand?) Message #2 Posted by Vieira, Luiz C. (Brazil) on 21 Oct 2006, 9:25 p.m., in response to message #1 by Matthias Wehrli
Hi, Matthias;
just a suggestion: by inspecting the transparent case, can you have an idea on how to open an original, black one? I believe it may have 'welded' halves (glue? ultra-sound welding?), but I can't tell for sure. I suggested the inspection on the transparent case based on the fact that, if it was built to hold original wand internals, it must have the same format and shape.
In time: do you intend to take picture(s) of this transparent case? I would like to see it.
Please, if you succeed, let us know.
Best regards.
Luiz (Brazil)
