Re: programing issues.... (33s) Message #5 Posted by Vieira, L. C. (Brazil) on 7 Oct 2006, 9:43 a.m., in response to message #1 by Jack
Hi, Jack;
there is a way to show some limited ALPHA messages, as Hal Bitton mentions in his mail. If you have the HP33S UserŽs Manual, page 12-14, under 'Using Equations to Display Messages', youŽll see that first you need to have a program line to set flag 10, then you should add an 'equation' as a program line (in this case, whatever you want, with no necessary math coherence). If flag 10 is set, program line with an equation causes the program to stop and the equation to be shown without being evaluated. Please, see the example at page 12-15. After that, to restore the condition of the equations being evaluated, flag 10 should be cleared after the message(s) is(are) shown. Otherwise, all other equations in the program would not be evaluated, instead treated as messages.
Hope this helps.
Cheers.
Luiz (Brazil)
Edited: 7 Oct 2006, 10:08 a.m.
