Re: 41CX alarm functions Message #4 Posted by Geir Isene on 6 Oct 2006, 3:27 p.m., in response to message #3 by Hal Bitton
I use ASCII files to store alarms. Format is MM,DD:HH,MM:MESSAGE
In this way, the first 6 characters (one ASHF) is the date, the next 6 is the time, then the message. The sequence would be to use GETREC, ANUM, then ASHF, ANUM, then ASHF and you are left with the message in alpha.
