Re: HP 39G connectivity cable Message #2 Posted by Ron Ross on 2 Oct 2006, 8:59 a.m., in response to message #1 by Marcus von Cube, Germany
I do not know the pinout of the Hp100/200 LX, BUT I DO KNOW IT IS THE WRONG CABLE, capable of frying the display of the Hp38/39/40G calculators. Whether it does or not is a crap shoot. (I learned this w/ my Hp38G in the same fashion, and luckily, I did not damage and hope you did not either).
The Hp39/39/40G calculators can use the same cable supplied with the original Hp49G and is fairly easy to obtain.
If your display is back to normal, you can resume your quest for an Hp49G cable. If you now have a blank screen or corrupted screen, you now have a new paperweight. While the display can be replaced, the Hp39G is not all that expensive via ebay. Hopefully, your Hp39G is no worse for wear.
