Re: Factorials on the Free42 Message #9 Posted by Karl Schneider on 27 Sept 2006, 9:50 p.m., in response to message #4 by Timespace
"Timespace" --
There is no such thing as a "fractional factorial". The Gamma function for non-negative real arguments is a smooth and continuous function that passes through all the discrete points of the factorial function, which is defined only for non-negative integers.
By definition, Gamma(x+1) = Integral (0, infinity, txe-tdt), so
Gamma(1) = 0! = 1
Gamma(2) = 1! = 1
Gamma(3) = 2! = 2
Gamma(4) = 3! = 6
and so forth...
I'm not certain what the basis of the definitions are, but I surmise that Gamma(x) is defined such that its first discontinuity as x decreases is at x = 0, instead of at x = -1. This effectively separates the behavior of the gamma function into regions of "positive x" and "negative x".
Factorials can be defined recursively such that n! = n*(n-1)! -- or alternatively, (n+1)! = (n+1)*n!. Defining 0! = 1 provides the basis for making the definition functional, and equivalent to n! = n*(n-1)*(n-2)*...*1.
Gamma is combined with factorial as x! on menuless or limited-menu models in order to conserve keyboard space.
Factorial (n!) is separated from Gamma on the HP-42S because the expansive menus make it feasible.
Note: Lower-end and business models, such as the HP-10C, HP-12C, and HP-17B* -- don't provide Gamma. These have only n!.
-- KS
Edited: 28 Sept 2006, 11:38 p.m.
