Re: 82164A as a controller? Message #3 Posted by Vassilis Prevelakis on 25 Mar 2006, 6:20 a.m., in response to message #1 by Steve Roberts
As Eric mentioned the 82164A cannot be a loop controller. However, you can transfer values from the multimeter to your PC by having something like an HP-71B read values from the multimeter and tranfer them to the 82164A.
There may be another possibility. You can place the 3468 in TALK ONLY mode in which case it sends a value to the HP-IL bus each time it is triggered.
The manual gives an example where you can use the 82162 printer and the 3468 in a loop without a controller. The 3468 is placed in TALK ONLY mode via a switch in the back and the 82162A in LISTEN ONLY mode by pressing both PRINT and ADV while turning it on.
I am not sure however whether the 82164A can be be configured in this way. Unless someone else on this list can help, you will have to look at the manual.
**vp
Edited: 25 Mar 2006, 6:59 p.m.
