Re: HP 45 input voltage requirements Message #2 Posted by Hal on 25 Mar 2006, 2:40 a.m., in response to message #1 by Bill Smith
Hi Bill. The ac adapter for the classic series (35,45,65,67,etc) actually puts out two DC signals: a 5.4 v signal to power the machine, and a constant current signal (which will read about 16vdc with no load) to charge the battery pack. This of course means that the AC adaptor contains rectifier circuitry. I've heard that the smoothing capacitors in the rectifier can go out which results in excessive ripple voltage, which can cause erratic operation of the calculator.
The bottom battery contact is positive one. Note that you'll need to have the adaptor disconnected from the calc to power it from the battery contacts. Also be sure that those little spring loaded plates in the adapter recepticle are making contact with the two outside pins, shorting them together (this is how battery power is routed to the calculator when the adapter is not connected).
Hopefully it's just a bad adapter... Best regards, Hal
