Re: HP 97 Self Diagnostics Message #2 Posted by Vieira, Luiz C. (Brazil) on 23 Mar 2006, 10:22 p.m., in response to message #1 by Brian Blackwell
Hi, Brian;
I have a working HP97 and, for as long as I know, these calculators have no specific buitl in, self-test feature. Anyway, their original Service Manual includes two programs that are used to test their features and locate, if applicable, in which ROM does the problem occur, I mean, if there is any problem with the calculator.
Anyway, if you make sure the batteries are fully charged and you place them correctly, simply turn it on, check if the display showns 0.00, try a few calculations, read/writ a magnetic card, print something and go ahead. (good) Chances are that your 'retired' HP97 becomes active in a heart beat. These small 'beasts' come from a time when daring was not exactly dreamming...
Success!
Luiz (Brazil)
