Re: HP 15C Keyboard Message #2 Posted by Randy on 8 Mar 2006, 8:12 p.m., in response to message #1 by Charles
If the key clicks okay and has the normal travel, it should be fine.
This is an adaptation from many posts from MoHPC regular David Smith:
"Your most likely problem is a dirty switch contact for the 9 key. These can be cleaned fairly easily if you open up the machine (one screw under each rubber foot).
Beneath each key dome is a tiny hole in the circuit board. Make a tiny wire brush out of three wire brush bristles twised together, mounted in a pin vise, and trimmed square. Place a drop of 91% isopropyl alcohol on the hole, dip the wire brush in more alcohol, and gently "scritch" around in the hole with the brush. In stubborn cases you may have to repeat a few times."
For more on how to open: http://www.hpmuseum.org/disasm.htm
Good luck, post again if you need more help.
