Re: 19c Message #2 Posted by Vassilis Prevelakis on 5 Mar 2006, 5:11 p.m., in response to message #1 by Walter B
if you do not use the battery pack, make sure the DC supply you are using is fully regulated, otherwise you are running the risk of damaging the CMOS RAM in your HP19C.
You did not mention whether you have the door to the battery compartment. If you do have it, things are much easier.
**vp
