Re: How can I make my PC print to HP82240B? Message #6 Posted by James M. Prange (Michigan) on 5 Mar 2006, 6:55 p.m., in response to message #5 by Eric Smith
Agreed; I don't know of any "easy" way to do it. Perhaps the least painful way would be to connect a calculator to the PC, and with the calculator in server mode, send it data and tell it to print it via IR. In other words, use the calculator as an RS-232/"RedEye" IR adapter.
I've heard of relatively simple RS-232/"Serial IR" (SIR) converters that can be used for communicating with the 48 series for transfers via IR, but I have my doubts about the feasibility of getting them to send in the RedEye encoding for the 82240 printers. Certainly it would be possible to make the hardware/software to do it, but it wouldn't be an "off the shelf" solution.
Regards, James
