Comparing the HP41 and HP48 (RPN/RPL subject) Message #1 Posted by Vieira, Luiz C. (Brazil) on 26 Feb 2006, 9:15 p.m.
Hi;
I decided to check the PDF file I let available related to the HP41 and HP48 comparison, and I saw that the file was created with the Acrobat Creator V3.0, and I forgot to set the `Save TTF character definitions` option when it was generated. So, some characters do not look as they should. I created it again, but now I used Acrobat Creator 7. Unfortunately, the final version is 650MBytes long... It could be smaller if I redraw all graphics, and I intend doing it later.
Well, here it is, the newer file.
Cheers.
Luiz (Brazil)
