HP-48 Turbo: [Was: Re: HP41CV Turbo Version- Modified Calcs] Message #4 Posted by Raymond Del Tondo on 15 Feb 2006, 2:52 a.m., in response to message #3 by John Kercheval
At least on my 48G+ with speedup,
you have to hold the ON key for about a second
to signal the calc to switch to turbo mode.
For normal usage, just press the ON key as usual.
When turning off the calc, it will revert to
normal mode automatically.
There are easy ways to determine if turbo mode is active or not:
Just press an empty menu key, or press SWAP (right arrow)
while there's only one or no object on the stack.
The resulting beep will have a much higher frequency
than normal if the calc is in turbo mode.
Most of the time normal mode will be sufficient,
at least for me, since I made my own software speedup,
which also accelerates input forms and choose boxes;-)
HTH
Raymond
