Re: HP41C/CV/CX Self Test Message #2 Posted by Raymond Del Tondo on 14 Feb 2006, 8:42 a.m., in response to message #1 by Mike T.
the HP-41 doesn't have a similar self-test built-in,
but you can check the most important things very easily.
I'd reset the machine first, clearing it's memory:
While the unit is off, press and hold the backspace key,
then press the ON key, then release both.
The unit should show 'MEMORY LOST'.
Press the bar keys, from left to right.
The first bar key turns the calc on,
the second switches to USER mode,
the third to PRGM mode, and the 4th to ALPHA mode.
If these modes are shown by the associated
annunciators in the display, these keys work.
Then switch back to 'normal' mode by pressing PRGM again.
Press [XEQ] [ALPHA] S I Z E [ALPHA] 0 0 0 , then press [PRGM] again.
On an empty CV or CX unit, the display will show '00 REG 319' .
This way you'll see that the RAM chips are there,
and are likely to work.
To ckeck if the display works, press [ALPHA],
then ABCDEFGHIJKLMNOPQRSTUVWX .
If you hear a beep when entering the X,
you have entered 24 characters. This is ok;-)
Now turn off ALPHA by pressing [ALPHA],
then press [ALPHA] again.
The display should show the string shifting to the left
in short intervals.
You can also check if all keys have the same tactile feedback
by pressing them one after the other,
and check basic functionality by doing some calculations.
If nothing unxpected happened so far,
the unit is likely to work.
Of course there are always chances for hidden defects,
like broken screw posts or corrosion,
but this will be visible from the outside;-)
In my experience the above key sequences
show at least that the basic machine works.
There exist some Diagnostic ROM modules for the HP-41,
which had real self-test functions built-in,
but these weren't available to the public,
and thus are next impossible to get.
HTH
Raymond
Edited: 14 Feb 2006, 8:47 a.m.
