Re: HP48, Battery Drain Message #2 Posted by Raymond Del Tondo on 11 Feb 2006, 2:09 p.m., in response to message #1 by John Kercheval
what do mean with 'quickly' ,
a week, a month, or half a year?
Have you checked if the calc
can be used much longer w/o battery change
if the cards aren't installed?
Another thought:
Do you heavily use software
or data from the RAM card?
Accessing 'covered' ports means
more work for the machine,
and more work means more battery drain;-)
Or do you simply use the calc heavily?
I have a Sparcom 512K GX RAM card in port 2,
and sometimes either an HP 128K card
or an 128K EPROM card in port 1,
and the batteries last for months.
Raymond
