Re: HP48GX, Commas Message #4 Posted by Marcus von Cube, Germany on 12 Feb 2006, 8:07 a.m., in response to message #3 by Raymond Del Tondo
Not to be confused with the thousand's separator,
which isn't supported on the HP-48,
at least not out of the box;-)
I'm afraid you're wrong. A soon as you set FIX mode, the thousands are seperated by "," or "." depending on the definition of the decimal point. This is at least true for my 48S. The 28S does not display thousands seperators.
Marcus
