Re: Case cleaning Message #2 Posted by Jeff O. on 7 Feb 2006, 7:28 a.m., in response to message #1 by Andreas Terzis
The problem you describe is very common. It seems to be due to the disintegration of the foam rubber layer between the inside liner and outside of the case. Many (myself included) have reported success with turning the case inside out and tossing it in the washing machine with a load of laundry (probably not a hot water load), then let it air dry. Of course, your results may vary, so try at your own risk.
