Re: 42X Message #5 Posted by HrastProgrammer on 23 Jan 2006, 1:10 a.m., in response to message #1 by CW (Maui, Hawaii)
Also I noticed elsewhere that you cannot save data to port memory, I assume then that you can save data to calculator memory?
If you mean HP-42X 'virtual' ports then yes, you can save only programs there (this is some kind of static program storage). In extended version of HP-42X you have 96K RAM which so you have plenty of memory available for data (and programs), I think.
This is from my page:
In addition to the 96K of HP-42S RAM, some versions of HP-42X support the port memory. Its purpose is to store programs for long term use. Data cannot be stored to port memory. Programs cannot be directly executed from port memory but they can be dinamically loaded to the main memory and executed. There are two ports inside HP-42X: Port1 (RAM port, size 16K for HP42X48L, 30K for HP42X49L and 31K for EXTENDED versions) and Port2 (ROM port, size 32K). These are 'virtual' HP-42S ports which have nothing to do with the real HP-48/49 ports. Port memory isn't affected by "Memory Clear".
