HP-97 battery contact replacement Message #1 Posted by David Ramsey on 10 Jan 2006, 10:31 p.m.
I'm working on Stephen Easterling's HP-97. His original complaint was that the "0" key did not work.
When I received the calc, the first thing I noticed were the corroded batteries (bad Stephen! You left them in!) One of the battery contacts had previously broken and been crudely soldered back into place. Unfortunately the solder joint broke flush with the plastic of the battery compartment when I removed the original batteries.
Anyone have any suggestions for fabricating a replacement battery contact? I'm thinking of using wire from a small paper clip, held in place on the other side of the battery compartment with a healthy dollop of plastic-friendly epoxy...
