Re: HP85 Message #2 Posted by David Ramsey on 10 Jan 2006, 10:28 p.m., in response to message #1 by Gary Abernathy
I've successfully repaired the drive wheels in desktop calc tape readers using heat-shrink tubing.
Take out the drive wheel (or tape drive assembly). Scrape off all the remains of the disintegrating drive wheel rubber. Get the bare metal wheel as CLEAN AS POSSIBLE.
Now hit your local electronics supply or Radio Shack. Find the smallest heat shrink tubing that just fits over the drive wheel. Back home, use a razor blade or very sharp knife to cut a piece just a millimeter or so less wide than the drive wheel. Slip it over the drive wheel and use a match or heat gun to shrink it.
Others have used 2 or 3 rubber O-rings of the proper size. These will probably result in a quieter drive, but the heat shrink tubing is easier to find.
