Half+Full nuts?(was: HP-41 contrast adjustment?) Message #7 Posted by Vieira, Luiz C. (Brazil) on 27 Dec 2005, 12:12 a.m., in response to message #4 by Geir Isene
Hi, Geir;
I have done such 'transplantation'. I have a halfnut HP41CV with a bad RAM (shows up only 63 registers) inside an original HP41C fullnut case. As mentioned in this thread, all of the inner package must be transplanted, LCD assembly included. Look at the picture below:
After removing the entire 'guts' from both calculators, it is necessary to cut out some small posts in the fullnut case (shown as black spots in the picture) prior to settle the halfnut main PCB. This is due to the fact that the halfnut main PCB does not have all small holes available in the fullnut main PCB. Appart from that, evertyhing else fits perfectly fine. The rounded-edge LCD frame is actually in the LCD assy itself, so it goes with the whole package.
Hopes this helps a bit.
Cheers.
Luiz (Brazil)
