HP Forum Archive 15
Alpha Rom from Angel Martin
Message #1 Posted by PeterP on 22 Dec 2005, 12:14 a.m.
Just wanted to check if anyone of you has done some investigation of the functions of the Alpha-Rom? I have tried to come up with the functions, and got stuck with a few. Anyone has some ideas? (simply could not hold my curiosity until the arrival of a QRG... ;-) )
Here is what I have so far (sorry for the bad format...)
Peter
	XROM	Name	Function
-ALPHA
aView	 6.01 	Lower Case AVIEW	Displays M&N with lowercases
ACL?	 6.02 	Is Alpha Clear?	Checks if Alpha is Clear. Skip if not true
Aleng?	 6.03 	Alpha Length	Reports back length of Alpha
AlengX	 6.04 	Make length of Alpha to x	Deletes n chars from left, to make Alpha as long as indicated by X-reg
AlengXY	 6.05 	Make alpha string of y char, x times	create a string in alpha with Char with code in y, x times repeated
AnumI	 6.06 	Anum Integer	Gets Integer Number from Alpha into x, -1 if none found
AnumDel	 6.07 	ANUM and Del	gets the value of the first number from the left into x and deletes all chars from the left to the end of the number
ArclChr	 6.08 	ARCL Chars	Append x chars from currently active file
ArclI	 6.09 	ARCL Integer	Recalls the integer portion of x into Alpha
Arev	 6.10 	Alpha Reverse	Reverses Alpha to its mirror image
ArotX	 6.11 	Alpha Rotation by X	Rotates Alpha by X chars
ASCII	 6.12 	ASCII	Get ASCII code of leftmost char into X
ASHFX	 6.13 	Alpha Shift by X	Deltes X chars from the left in Alpha
ASTOXX	 6.14 	Asto in X, x chars	stores x chars from the left into x
ASUB	 6.15 	Alpha Substitution	Substitutes the Char at pos Y with Char X
ASWAP	 6.16 		??? Creates "Private when one goes to PGM mode"
AEXEQ?	 6.17 	Execute Alpha	Checks if a lable like alpha exists, if so executes it, if not skips a line
A>RG	 6.18 	Alpha to Regs	Stores alpha in 4 cons regs, starting at x
A>ST	 6.19 	Alpha to Stack	Copies reg MNOP to Stack registers
A<>ST	 6.20 	Alpha Exchange Stack	Exhchanges the context of the alpha regs with the stat regs
ChrSet	 6.21 	Char Set	Shows all available characters, scrolling through the screen
ClaC	 6.22 	Clear Alpha from Comma	Clears Alpha from the Comma to the right
DCNT	 6.23 	Set Display Contrast	sets display contrast to value in x
DCNT?	 6.24 	What is Display Contrast?	Retrieves the currently active display contrast into x
DCNT+	 6.25 	Increase Disp Contr	Increases the current display contrast by 1
DCNT-	 6.26 	Decrease Disp Cont	Decreases the current display contrast by 1
Display	 6.27 	Display the Alpha	Display Alpha reg, maybe some difference with printer etc…
Dtest	 6.28 	Display Test	Light up all segments of the display
Ladel	 6.29 	Left Alpha Del	Deletes the leftmost char
LadelX	 6.30 	Left Alpha del by x	deltes the x leftmost chars from Alpha
LAtoX	 6.31 	Left A to X	Deletes leftmost char and puts code in X, just like ATOX from the X/F mod
Left$	 6.32 	Left String	Keep x leftmost chars
Low$	 6.33 	Low String	Replace all upper chars with lower case charts
Mid$	 6.34 	Mid String	Kepp chars x to y
M<>N	 6.35 	Switch M and N
M<>O	 6.36 	Switch M and O
N<>O	 6.37 	Switch N and O
PMTA	 6.38 	Prompt A	Prompt for Text entry
PosAX	 6.39 	Pos of x in Alpha	Puts the position of the char with the code in X into X
PostFX	 6.40 	Post found X	find char in x in alpha, delete all to the left of the found char
PostSP	 6.41 		???
Prefx	 6.42 	Pre found X	find char in x in alpha, delete all to the right of the found char
PreSP	 6.43 		???
RADel	 6.44 	Right Alpha Del	Deletes the rightmost char, like ABSP
RAtoX	 6.45 	Right Alpha to X	Seems to not be working. Supposedly takes right alpha char and puts char code in x
RemZer	 6.46 	Remove Zeros	Remove leading zeroes from String
Right$	 6.47 	Right String	Leaves x chars from right in Alpha
RG>A	 6.48 	Registers to Alpha	copies 4 consec regs starting with x into Alpha
St>A	 6.49 	Stack to Alpha	Copies Stack regs into Alpha
ToglC	 6.50 		???
Upr$	 6.51 	Alpha Upper	Replace all lower case chars with uppercase chars
ViewA	 6.52 	View Alpha	Show Alpha, maybe some special treatment of printer
XAtoX	 6.53 	Alpha to X by X	Puts char code of (x+1)th position in x, alpha undisturbed
XtoAI	 6.54 	X to A Integer	Appends integer of x to Alpha
XToAL	 6.55 	X to Alpha left	puts char with code in x into alpha on left
XToAR	 6.56 	X to Alpha Right	puts char with code in x into alpha on right
YToAX	 6.57 		??? Data Error
-Sound FX Buzzon 6.59 Buzz On Turns a CPU buzz on NoBuzz 6.60 Buzz Off Turns the CPU buzz off ClaxOn 6.61 Claxon A new "Beep" Rasp 6.62 Rasp Another "Beep" ToneXY 6.63 Tone by X and Y Y is length (ie number of repetitions) and x is pitch (lower = higher)
Edited: 22 Dec 2005, 12:15 a.m.
Re: Alpha Rom from Angel Martin
Message #2 Posted by Howard Owen on 22 Dec 2005, 12:27 a.m.,
in response to message #1 by PeterP
	XROM	Name	Function
.. PostFX 6.40 Post found X find char in x in alpha, delete all to the left of the found char PostSP 6.41 ??? Prefx 6.42 Pre found X find char in x in alpha, delete all to the right of the found char PreSP 6.43 ??? ..
Given the context and the names, might these find and remove trailing and leading spaces as the case may be?
Message #3 Posted by Vieira, Luiz C. (Brazil) on 22 Dec 2005, 1:14 a.m.,
Hi, Peter;
I tried some of the ALPHA ROM features, but I did not dig too deep as you did. Allow me to congratulate you!
About YTOAX (Y TO A through X-index), the Extended IO has a function with the very same name. If the ALPHA YTOAX works the same (hopefuly), it places the character defined by the ASCII code in Y to ALPHA, in 'X' position. If X is positive, left-to-right count; if X=0, leftmost character; if X is negative, right-to-left count. So: (using Extended IO YTOAX)
               [ABCDEFGHI  ] (ALPHA contents)
79    ENTER                  (ASCII dec code for 'O')
3     YTOAX    [ABCOEFGHI  ] (resulting ALPHA)
[CHS] YTOAX    [ABCOEFOHI  ]
Hope this helps.
Cheers.
Luiz (Brazil)
Edited: 22 Dec 2005, 1:17 a.m.
Message #4 Posted by PeterP on 22 Dec 2005, 10:20 a.m.,
in response to message #3 by Vieira, Luiz C. (Brazil)
Luiz,
thanks for your kind input. I tried that version (and quite some variations of it) remembering the Ex-IO function. However I only get "Data Error" in the display...
Message #5 Posted by Doug Wilder on 22 Dec 2005, 6:24 a.m.,
Hi Peter,
Angel copied several functions from the Bldrom for the AlphaRom. So Bldrom manual will describe these.
For example ALENGX allows plus of minus argument in X for left or right padding of spaces or stripping of characters. Similar for ALENGXY (makes alpha X chars long using char in Y (pads or strips)), ASHFX, ASTOXX (from left if pos right if neg, X in LASTX after). PRESP and POSTSP strip characters after or before the first space character (prefix and postfix parseing). PREFX (prefix) and POSTFX (postfix) using the character specified in X (either decimal, text or NNN). DISPLAY sends the text line that follows to the LCD display using unique LCD setting for each of 256 different bytes and only prints if in NORM or TRACE. A couple of bldrom functions have been renamed (XAI and AXI). You have AXEQ? and ACL? correct!
Best Regards, Doug
Message #6 Posted by PeterP on 22 Dec 2005, 10:21 a.m.,
in response to message #5 by Doug Wilder
Doug,
Thanks! Great corrections & additions!
Peter
