Re: HP 3468A US / German voltage selection Message #5 Posted by Etienne Victoria on 20 Dec 2005, 4:20 p.m., in response to message #1 by gebripe
Hallo Günther,
Yes, you can change the voltage selection on the 3468A/B but, contrary to the frequency, the change must be performed internally.
You have to open the multimeter. inside, you have to solder a jumper (J701) between 2 connections that will provide you with the desired voltage.
The precise scheme to follow is given on page 2.1 figure 2.4 of the 3468A/B service manual.
More precisely on this page:
After soldering and double-checking your soldering...
Test & enjoy!
MfG aus Frankreich!
Etienne
Edited: 20 Dec 2005, 4:22 p.m.
