Re: HP 41CV Message #3 Posted by Artur - Brasil on 15 Dec 2005, 1:06 p.m., in response to message #2 by Jeff O.
If none of the steps listed before didn't work, you may have a trouble in the screws bases, on calculator's back.
Press the calculator (in the line of upper foot) against a table and try to turn it on.
As these calculators are old, the plastic under screws breaks and the back part can't press the battery/modules contact against the main board.
To really check this, remove the back foot and screws and open very carefully the calculator. Look at the plastic where the screws pass thru.
Good luck!
Artur
