Re: Stuck HP 28 Message #5 Posted by dl on 18 Dec 2005, 2:19 a.m., in response to message #4 by Thomas Falk
Well, I've done it, but unfortunately, it has also reset the memory ("Memory Lost"), which is what I was trying to avoid. After all, I could achieve the same result by simply opening the batteries cover.
Meanwhile, I got to see the manual, and this operation you recommended (ON + ^) should really do only a "System Halt", not a "Memory Reset" (i.e. stop the running program, without resetting the memory). So I really don't understand what has happened.
Thanks anyway for your kind help.
Edited: 18 Dec 2005, 2:30 a.m.
