Re: something growing inside 48SX bezel Message #6 Posted by Han on 14 Dec 2005, 12:09 p.m., in response to message #5 by Jim Rudnick
There is a way to open the HP48 without causing any cosmetic damage. This allows access to the PCB. However, if you wish to get underneath the bezel, then the only method is to pry it up, causing much bending and whatnot to the faceplate. In my opinion, I would just leave it be -- cleaning with something like "klear screen" (an LCD, laptop, computer cleaner solution to be applied to a cleaning cloth) is probably the best bet. A few hairlines caused by the worming effect is better than a bent faceplate.
