Re: 82143 Printer Cable for HP41 for I/O Message #2 Posted by Eric Smith on 4 Dec 2005, 5:10 p.m., in response to message #1 by Philip
I hacked up something to montitor the signals over that cable and output the data bytes on an EIA-232 serial port. It depended on the printer still being attached and handshaking properly with the module electronics. It would be more difficult to replace the printer entirely.
But unless you have a source of lots of 82143A printer modules (sans printers), what's the point? Designing a one-off interface usinng the 82143A module would be quite a lot of work. It's much easier to just get an 82160A HP-IL interface and an HP-IL converter (serial, GPIO, or HPIB) and use that to connect things.
The closest thing to specs for the signals on that cable that has been seen outside HP would be the documentation on the NPIC chip, which can be found on TOS. It's a clocked synchronous protocol.
