Re: Charger 82002A HP 80 parts Message #2 Posted by Randy on 3 Dec 2005, 1:20 p.m., in response to message #1 by Gerardo Rincon
Attached to another 82002A... They don't exist otherwise as it is a custom molded HP part.
The most common problem is fractured wires were it enters the connector. One solution would be to carefully slice it open, shorten the cable and solder the wires to the pins. It can be done in such a way as to be almost invisible.
Total replacement is another possibility.
