Re: HP48GX crash problems Message #6 Posted by Han on 1 Dec 2005, 5:05 p.m., in response to message #5 by Jeff
Is there anything running in the background, such as say Eqstack? If you are not running any downloaded software, and use only the built-in commands, then you should not be experiencing these crashes. The fact that your screen is garbled means something is trying to write to random areas in memory, including the memory containing the content of the display area. Can you be more specific about the conditions leading up to the crash?
E.g. commands you used, programs you ran, memory conditions (low ram available, etc), where you run the program (from var, port0, port1, or higher ports) etc...
