Re: 14B Calculator - change # of decial places Message #2 Posted by Vieira, L. C. (Brazil) on 27 Nov 2005, 5:05 p.m., in response to message #1 by T.Ulch
Hi, T. Ulch;
please, locate the "close paenthesis" key [)] in your calculator and you'll see [DISP] printed in orange (gold?) over the key, in the keyboard faceplate. To access the DISP menu, press the shift key, wiht a small orange (golden?) square printed on it, over the ON/[C] key; you'll see that a menu with four options apper:
[FIX ALL . ,]
If you press [PV] key, the calculator will show all significant digits of the mantissa of the number in the display till the last non-zero to the right side of the fraction part. You can check:
2 [SHIFT]1/x -> [ 0.5 ]
8 [SHIFT]1/x -> [ 0.125 ]
[C] -> [ 0 ]
If you choose a fixed number of decimal places, [SHIFT][)] again and [FIX]; then youŽll see:
[ FIX _ ] so you can specify how many digits you want, frm 0 (only integer part) to maximum of 11. Rounding occurs according to the last not-shown digt: if less than 5, last visible digit remains; if greather than of equal to 5, last visible digit is increased one unit.
To specify a number of digits of the fraction part, simply press any number key from [0] to [9] after seeing[ FIX_ ] If you want 10 or eleven fixed digits, press [.] (dot) key to change from
[ FIX _ ] to
[ FIX 1_ ] then [0] or [1]. Try this:
[SHIFT][DISP][N][4] -> [ 0.0000 ]
2 [SHIFT]1/x -> [ 0.5000 ]
8 [SHIFT]1/x -> [ 0.1250 ]
[C] -> [ 0.0000 ] Hope this helps.
Cheers.
Luiz (Brazil)
