Re: New version of SandMath-III Message #3 Posted by Vieira, L.C. (Brazil) on 14 Nov 2005, 3:54 p.m., in response to message #1 by 聲gel Martin
Hi, 聲gel;
thank you for the updated version.
Please, forgive me asking this particular question: is it available through TOS? If so, is it just to follow existing SandMath-III link?
In time, I asked for a copy of the QRG and did not receive it (maybe I spelled the wrong e-mail address). Is the QRG available through TOS, too?
If not, would you re-send it, please?
lcvieira (at) quantica (dot) com (dot) br
Thanks you and sorry for the inconvenience... d8^)
(BTW, the 41Z.ROM is a wonderfull achievement, congratulations. Do you think that separating a block of, say, six registers in main memory, like it is done with appointments and assignments, and use these registers to emulate a complete, four-register complex stack would enlarge too much the original 41Z size? I mean, considering that separating a block of registers this way is possible. Just one thought...)
Luiz (Brazil)
