Re: nonpareil HP 41 emulator Message #2 Posted by Eric Smith on 13 Nov 2005, 2:30 p.m., in response to message #1 by Guido Ostkamp
There's not currently any standard keyboard mapping for that. You can edit the keyboard mapping in the files 41cv.kml and 41cx.kml. The lines that begin with "scancode" control that. Example:
scancode 105 map 105 24 end # i
is the line that maps the "i" key on the keyboard to row 2 column 4
of the keyboard.
The numbers after "scancode" and "map" have to match. The values that are available may be found in gdkkeysyms.h
You're welcome to suggest some standard mappings for those keys.
I'm considering F4 for ON, F5 for USER, F6 for PRGM, and F7 for ALPHA, F8 for SST, F9 for R/S, and TAB for shift (gold). If you want to try those, you can use these KML files:
