Re: 41cx on button Message #4 Posted by Diego Diaz on 13 Nov 2005, 8:32 a.m., in response to message #3 by Hal
It's a somewhat common problem on used machines.
Mostly due to some dirtiness between the steel key-dome and the KB PCB.
Light cleaning involves taking your 41 apart, turn the upper half (keyboard) upside down, place one drop (means *just* one) of iso-propyl-alcohol thru the small PCB hole under the afected key(s) while repeatedly pressing such key.
This will fix mostly any not-so-bad key contact. For the severe cases (of dirtiness) you should get a very thin and soft paintbrush. Thin enough to pass thru said small hole, and soft enough to bend its whiskers inside the key dome. DO NOT PUSH, just rotate CW-CCW gently after placing one IPA drop and pay attention not to leave any loose whisker around.
Keyboards with physical damage (not just dirtiness), may require complete disassembling of the KB PCB, which is by no means advisable unless you are a very skilled technician...
Hope this helps.
Diego.
