MLDL2000 assembly pics Message #1 Posted by Vieira, L.C. (Brazil) on 11 Nov 2005, 11:28 a.m.
Hi MLDL2000 owners, all;
After trying many possible solutions, I could not find a suitable connector to be used between the CPDL and the USB boards, so I used a cut of flat cable. This link leads to the pictures of the boards with connectors and their arrangement. The MLDL2000 works perfectly fine the way it is. Main final stages are 1) to build a suitable block of pins to connect the interface board to the CPLD board and 2) to fimrly locate the USB connector so it does not slip when plugging the cable in or out.
The last picture shows my own solution for an external DC input. Although it can be seen, the box has already been cut to hold the USB
These are just intermadiate pictures. As I have it finished and completely assembled I'll post others.
Hope you enjoy. Feedback is welcome.
Cheers.
Luiz (Brazil)
Edited: 11 Nov 2005, 11:34 a.m.
