Re: 42s hardcover flip-case Message #2 Posted by Bill (Smithville, NJ) on 9 Nov 2005, 7:23 a.m., in response to message #1 by ECL
These were hard plastic cases made by Astech Industries many many years ago. I was fortunate enough to get two of them several years ago when a gentleman here was selling his last remaining stock of new ones.
Mine are on two of my HP-42S. They are great cases, especially if you, like me, use your 42s on a daily basis. The overlapping lip on the edges does a good job of sealing out most of the dirt/dust. Since I carry my 42S in my briefcase and out to job sites, the hard case gives it a lot more protection and is quicker to access than using the standard slip case.
The case has a raised tab on each side that matches the grove on the side of the calculator so that the calculator is securely locked into the case. I believe most of the Pioneer models should be able to fit.
As you can tell, I am a great fan of this case. I only wish I had two more. I know, I'm greedy - but aren't we all when it comes to our favorite toys.
Bill
