Re: 1.5V "AA" will break the battery contacts... Message #6 Posted by Karl Schneider on 8 Nov 2005, 12:39 a.m., in response to message #5 by Paul Marin
Paul stated,
Contacts have flattened yes, but remain this way with no other forces on them. The pressure of the batteries is very light. They will fracture if bent backwards and then re-flattened continiously, but if they stay as they are, there is no problem.
If the contacts have flattened, then some metal fatigue has already taken place. The force of contact using longer cells is certainly higher than intended by design. Certainly, repeated flexing due to continual removal and re-installation of cells would fatigue the contacts faster. If you are using disposables (as indicated by "1.5V") and are also using the calc regularly, replacement will be required. That's why the HP LED-based models were designed for rechargables.
The two HP-34C's I bought on eBay turned out to have fractured battery terminals. I strongly suspect that this was caused by use of longer 1.5V disposables after the US$12 (in the 1980's!) rechargeable pack gave out. One of them was advertised as having good contacts, but one contact simply broke upon a light touch. It looked fine, but clearly was fatigued and cracked.
-- KS
