Re: Gummy wheel repair , Need O=-ring size Message #2 Posted by Mike DiGirolamo on 28 Oct 2005, 2:44 p.m., in response to message #1 by Frederick Harvie
Fred,
I've tried to measure the ones I've been using successfully. Be mindful that these are made of rubber hence, are a bit difficult to measure.
The ID is from 0.1181" (3mm) to 0.125" (1/8"). I suspect a tight fit would be correct to hold snugly on a 1/8" shaft.
The OD is ~0.250" or 1/4".
Sorry I don't have a gear out right now that I could directly measure for you.
Hope this helps,
Mike
PS If you have any problems finding the ones you need, drop me an email.
