Re: HP71B -> HP 41CX (HP-IL) Message #4 Posted by Vassilis Prevelakis on 26 Oct 2005, 1:25 p.m., in response to message #3 by Gileno
Gileno wrote:
> I have a HP41CX, HP9114B and a connected HP71B for HPIL. How do I
> record files in HP9114B using HP71B?
For accessing the diskette drive from the HP-71B, it needs to be
the loop controller. Since you cannot have two loop controllers and
the software on the 41C assumes that *it* is the loop controller, you have to remove the 41C from the loop. Then you can save files on the 9114B from your 71B. You can then reconnect the 41C and either place the 71B in slave mode or (even better) remove it from the loop.
Read the HP-IL Interface Owner's Manual, file 82401a.pdf in the MoHPC DVD.
**vp
