NiMh 500mah 'N' Cell Source Message #1 Posted by Donald Leonard on 25 Oct 2005, 12:32 p.m.
For those of you looking for the highest capacity 'N' cells, here is a source I just found:
[url]http://www.tnccustomproducts.com[/url]
Click on the "Battery" heading on the left. They also have the highest quality 'N' cell to 'AA' battery adapter for charging I have found. I own two different adapter types, and these (my third) are by far the best. They are worth buying even if you already have a set.
These batteries took 3 full hours to charge on my 5 hr. NiMh fast charger that came with my 2300mah 'AA' battery set. I expect that it will take about 1 1./2 - to 2 hrs. with subsequent charges.
PLEASE - no more warnings about corrosion doom from you experts out there. It has been published over and over. I personally don't buy the claim. ALL BATTERIES can cause corrosion - even the highly touted alkaline. NO BATTERIES should be stored in the '41. This 'heads-up' is not for the nay sayers - it is ment for those who ARE trying to find the highest capacity and best quality 'N' cells available. These will do nicely.
Donald
Edited: 25 Oct 2005, 12:35 p.m.
