41CV Back from the Dead Message #1 Posted by Les Bell on 22 Oct 2005, 1:49 a.m.
A few days ago, I thanked HrastProgrammer for posting the story of his successful 48G repair; as I mentioned, I like "happy ending" stories.
This motivated me to drag out a 41CV which had been languishing in my desk drawer - it had long ago suffered from corrosion damage, and while I'd screwed in a small piece of bent metal with a soldered connection to the expansion connector block, that fix hadn't "taken" and it subsequently failed again. So, feeling inspired by HrastProgrammer, I dragged it out and disassembled it. There was a small bit of either corrosion damage or wear of some kind where the expansion block contacted the main board, so I cleaned that up, reassembled the calculator, inserted batteries and was rewarded with a "MEMORY LOST" message. A simple fix, really.
I'm left with one, slight, cosmetic problem, though. In peeling off the rubber feet, a couple of them seem to have "delaminated" - in prying up the first foot, it left behind a thinner layer of rubbery plastic which came off separately. Rather than use a sharp knife on the second one, I used a screwdriver to pry it up, but this just "scrunched up" the thin layer in such a way that I couldn't flatten it out again. In the end, I just peeled those two feet apart and threw away the inner layer, so now they are noticeably thinner than the other two (which had peeled off successfully). They're not particularly securely stuck in place now, either.
Has anyone else encountered this? My suggested fix is just to peel apart *all* the feet, and then reattach them to the calculator with some rubber cement - the feet will be a bit thinner, but I can live with that. Any other suggestions?
Best,
--- Les
[http://www.lesbell.com.au]
