8291001 - Logical Interchange Format (LIFG)
8291002 - Logical Interchange Format (LIFg)
Provides LIF type 1 interchange to allow file transfer to 9826,
9642, RTE-7. (Contains both binary and BASIC programs).
8291030 - FORMS/80
FORMS/80 is a data entry/display package created to
simplify application programs that require data entry/display,
provide a convenient user interface, and provide independence
of the CRT Form from the Applications program. Consists of 3
binary programs, two for the creation and modification of a form;
the third provides operating system and BASIC language extensions
which allow a BASIC program to utilize the form.
8291035 - Enhanced String Input/Cursor Control (LINCURg)
Binary program designed to enhance string input by allowing
you to input any character (including the comma and
quotation marks) as a string variable and to move the
cursor to any location (of the alpha display) on the CRT.
8291036 - Immediate Execute Keys (KEYONg)
Binary program designed to define any key on the
keyboard as an immediate-execute key (similar in
operation to the special function keys).
8291002 - Graphics Tablet Display (TRACK)
8291003 - Graphics Tablet Display (TRACKg)
binary program designed for use with the 9111A Graphics
Tablet. TRACKg uses the CRT as a visual display of the
movements of the pen on the tablet. The program can be
very useful in generating graphics when used in
conjunction with the BREAD function in the Plotter ROM.
8291010 - String/Retrieving Programs as Data (GETSAV)
8291011 - String/Retrieving Programs as Data (GETSAVg)
Normally, Series 80 computers store programs in their own
unique internal language. GETSAVg is a binary program
designed to enable you to store and retrieve programs as
data. When a program is saved as a data file, it can be
read, modified or rewritten as string data by other
programs.
8291012 - Sorting Groups of Elements of a String (SORTB2)
8291013 - Sorting Groups of Elements of a String (SORTB2g)
SORT2B is a binary program designed to sort groups of
elements of a string. Two sort procedures are available.
Both produce the same result, however, one of the procedures
requires no additional memory to operate.
8291015 - Enhanced String Manipulation (STRNGB)
8291016 - Enhanced String Manipulation (STRNGBg)
STRNGBg is a binary program which contains eight
programmable string functions designed to enhance string
manipulation. The functions are as follows: 1) highlight,
2) lowercase, 3) repeat, 4) reverse, 5) trim, 6) rotate,
7) search and replace, and 8) number of manipulation.
8291018 - Mathematical Functions (MATHBIg)
MATHBIg is a binary program containing nine programmable
mathematical functions including hyperbolics, octal to
decimal and decimal to octal conversions and factorial.
8291020 - Numeric Array Organization/Initialization (REDGZERg)
REDZERg is a binary program designed to enhance numeric
array manipulation capabilities of the HP86/87. A numeric
array can be reorganized (redimentioned) or initialized to
zero with use of one of the two statements offered.
8291021 - Programmer Control of CRT/Keyboard (IPBIN)
8291022 - Programmer Control of CRT/Keyboard (IPBINg)
IPBINg is a binary program designed to provide programmer
control of the internal CRT and keyboard. Capabilities are
intended to make development of a good terminal emulator
possible. Capabilities provided are also intended to be of
general use in CRT control or special keyboard entry or
control.
8291023 - Enhanced CRT, Cursor, Keyboard Control (FORMSB)
8291024 - Enhanced CRT, Cursor, Keyboard Control (FORMSBg)
FORMSg is an binary program designed to enhance control of
the CRT, cursor, and keyboard. The functions or expressions
offered are: page, cursor, xpos, ypos, home, readchar,
writechar, key1, key2, key3, setkey, and end key.
8291032 - Graphical Cursor (GCURS)
8291033 - Graphical Cursor (GCURSg)
This is a binary program designed to provide graphics cursor
capabilities. You should be familiar with the Graphics
Section of the HP-86/87 Owner's Manual and Programming
Guide.
