Re: 3468A Help !!!! Message #3 Posted by don wallace on 15 Oct 2005, 9:53 p.m., in response to message #1 by HP3468A
You may be able to make the instrument work better for you if you
put a high value resistor and maybe a bit of capacitance across the inputs.
Say, 4.7 Megohm 1/4 watts (yellow, purple, green, gold bands) and maybe 10 nF 630 volt greencap to settle the instrument.
It's possible that the input op amp has been degraded by some overloads during it's working life and the on-chip input transistors are a bit leaky. Maybe you could replace it?
DW
Edited: 15 Oct 2005, 9:53 p.m.
