HP-41 Flags Message #4 Posted by Vassilis Prevelakis on 12 Oct 2005, 5:34 a.m., in response to message #1 by Gonzalo Fernandez (Spain)
Gonzalo Fernandez (Spain) wrote:
> what SF? or CF? command must be input to the HP41 in order to
> get every key you type appears in the monitor?
Flags 15 and 16 control the setting of MAN, NORMAL and TRACE modes.
Following is a list of the various HP-41 flags and their function:
flags.txt
00 \
01 |
02 |
03 |
04 |
05 > User Flags
06 |
07 |
08 |
09 |
10 /
11 Auto Execute
12 Double width
13 Lower Case
14 Protection Override
15 Print Control Flag 1 (15 Clear: 16 Clear = MAN, 16 Set = NORM)
16 Print Control Flag 2 (15 Set : 16 Clear = TRACE, 16 Set = TRACE/STACK)
17 Suppress LF/CR (Record Incomplete)
18 Interrupt Enable (HP-IL Dev Module)
19
20
21 Printer Enable
22 Number Input
23 Alpha Input
24 Range Error Ignore
25 Error Ignore
26 Audio Enable
27 USER Mode
28 Decimal Point
29 Digit Grouping
30 Catalog Flag
31 Date Format (Set=DMY, Clear=MDY)
32 HP-IL Manual I/O Mode
33 IL Lock (HP-IL Dev Module)
34 Auto Address (XIO Module: Set=ADROFF, Clear=ADDRON)
35 Disable Auto Start (Mass Duplication Module)
36 Number of Digits (4)
37 Number of Digits (3)
38 Number of Digits (2)
39 Number of Digits (1)
40 Display Format (Fix)
41 Display Format (Eng)
42 Grad Mode
43 Rad Mode
44 Continuous On
45 System Entry Flag
46 Partial Key Sequence
47 Shift Set Flag
48 Alpha Mode Flag
49 Low Battery Flag
50 Message (PROMPT, VIEW, AVIEW)
51 SST Flag
52 PGRM Flag
53 I/O Request Flag
54 Pause Flag
55 Printer Existence
