Re: Need help for a 32 e Message #2 Posted by Vieira, Luiz C. (Brazil) on 7 Oct 2005, 1:37 a.m., in response to message #1 by Jürgen Richter
Hi, Jurgen;
I`d guess you are in no trouble. Since yours is an HP32E, all IC's are lined up by assembling them all pointing the '#1' pin to the LED display. All of them. And there's more: if your HP32E has more than one 8-pin DIP IC (the small ones, as you surely know), keep in mind that they have all pins with the same number connected in parallel with the ones in the other IC's (these are mainly RAM and/or ROM). You can easily check for this fact by inspecting the main PCB.
The main concerns are related to the series with continuous memory (HP33C, 34C and 38C). In these cases, the first position for the small 8-pin DIP IC's, the one closer to the power supply board, must hold the RAM IC so it is always fed for as long as there is a battery maintaining the minimum supply needs to hold its contents.
If you need further advice, please, keep posting.
Best regards from Brazil.
Luiz
Edited: 7 Oct 2005, 1:41 a.m.
