HP Forum Archive 15
Unknoun 'Hex' Annunciator on HP10b
Message #1 Posted by Raul Leslie C. on 25 Sept 2005, 10:03 a.m.
I've got an old HP10b (1987) but it has an 'Hex' Annunciator on the display, that I want to turn off.
In the manual I didn't found anything about this message.
Please can someone help me with this problem.
Thanks. RLeslie.
Re: Unknoun 'Hex' Annunciator on HP10b
Message #2 Posted by randy on 25 Sept 2005, 10:26 a.m.,
in response to message #1 by Raul Leslie C.
Just erase memory and it should remove the hex annunciator. From the manual:
Press and hold down [C], then press and hold down both [N] and [E+]. Memory is cleared and the ALL CLr message is displayed when you release all three keys.
Message #3 Posted by Raul Leslie C. on 1 Oct 2005, 10:52 a.m.,
in response to message #2 by randy
Randy,
It worked fine.
Thanks for your help. RLeslie
Message #4 Posted by GE on 3 Oct 2005, 3:59 a.m.,
in response to message #3 by Raul Leslie C.
Interesting, what is this indicator supposed to be used for ? Probably nothing on the stock 10B, so was there supposed to be another model on this hardware base with base conversion functions ?
Message #5 Posted by Randy on 3 Oct 2005, 8:35 a.m.,
in response to message #4 by GE
The 20S provided HEX/DEC/OCT/BIN functions.
