Re: Voyager emulators Message #5 Posted by Mike T. on 6 Oct 2005, 4:07 a.m., in response to message #1 by Ricardo Lira Matte
Ricardo -
Your simulators certainly look the part they have very realistic appearance!
The arithmetic accuracy isn't what I'd expect from an HP calculator though, and you should know that this can (and will) cause problems with a number of programs.
As an example try the following
48 - 47.8 - 0.2
The answer should of course be zero but it isn't and any test for x=0 will fail.
To be a true replacement your simulations need to match the accuracy of the real thing.
Mike T.
