Re: 48-series question about downloads from PC Message #2 Posted by James M. Prange (Michigan) on 23 Sept 2005, 3:23 a.m., in response to message #1 by Stephen Easterling
The files are best written on a "text editor", but a "word
processor" will work as long as you save the file as plain text,
to avoid having word processor control codes and sequences added
to the file. I don't know about Excel.
I suggest first uploading a variable from the calculator to the
PC, to see how the transfer header should look.
"ASCII" mode transfers to/from the 48GX can be done with Kermit,
but assuming a recent version of MS Windows, the
Kermit-based
HPComm ("HP PC Connectivity Kit") may be easier.
By installing the Xmodem Server library that's included with the
Xmodem-based
Conn4x ("hp48gII and hp49g+ PC Connectivity Kit"), you can
use Conn4x for "text" transfers, which are very similar to Kermit
"ASCII" transfers, and should be faster.
Try some searches of the newsgroup
http://groups.google.com/group/comp.sys.hp48?; useful search
strings may be "transfer header", "ASCII transfer" and
"translation".
Regards, James
