First Experiment Message #4 Posted by Pierre Brial on 22 Sept 2005, 9:32 a.m., in response to message #3 by don wallace
Thanks, Don & Etienne, for these informations.
As it is easier for me to find capacitors than inductors, I first removed the KG2 capacitor, and try to run the calculator without it.
What a surprise ! the calculator works perfectly, but now at warp speed. The ON-X test is completed in 3 seconds instead of 13.5 seconds usually, so a speedup factor of 4.5. I run the ON+ test during 10 mn without trouble, and the ON/ test is OK.
Programs run nearly instantaneously, and financial calculations are very fast (time is money, you know that).
Well, I recognise that it is suspicious that such an easy improvement have not already been made by HP. There will be probably drawback, so I keep watching my calculator during the next weeks.
Pierre
