HP broken : help! Message #1 Posted by Claudio on 20 Sept 2005, 12:09 p.m.
Hello, I need your help because my HP100LX is broken (I know, it isn't a true calculator but please, I really need some help....).
While it was connected to the external power supply it was overheat near the power connector and then it was off.
Now with the batteries all it's ok, but with only the external power supply it's all off.
I have opened it and I have found a smd component with a melted plastic case. It's the first component on the line from the power supply connector.
I can read that this component is a "15DM" in a SO23 case, but I don't know what kind of semiconductor it's, and how substitute it (possibly with an original replacement). I suppose that it's a diode to protect the HP by reverse polarity of the supply, but I am not sure.
Is there anyone who knows this component and where I can find it?
I can send you a picture of the pcb of the HP with the broken component.
Thank's very much for any help.
Best wishes,
Claudio
(remove the double _nospam_ from my e-mail address)
1234
