Re: Saxon Calculus and Hp49+ Message #7 Posted by I, Claudius on 15 Sept 2005, 11:01 p.m., in response to message #5 by Stacey Bower
I think you want to plot or table this function and then get values?
The 48/49/49+ create plot variables when plots are created. A neat way to keep these variables from cluttering up the Home Directory is to create a new directory for your plots. Type Plot then the command CRDIR. You will see a newly created directory named Plot. Press the F key under the Plot name and you enter this new directory. All the variables will be blank at this time. To delete any EQ, PPAR, ZPAR variables, enter them on the stack and type PURGE. To exit this directory use the commands UPDIR or HOME.
There are many ways to create plots, using (hold) Left-Shift (Y= or GRAPH) and the manual does a pretty decent job of describing this. You can also access the old 48 plot menu by typing 81. MENU , if you have the soft menu flag 117 set, -117 SF
You can also easily create a table of values for the function using the (hold) Left Shift TABLE function. This may the best way of getting what you want. I realize I'm not guiding you step by step and I apologize, I'm just very busy at the moment.
Edited: 15 Sept 2005, 11:11 p.m.
